Tranny fluid change?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-11-2007, 03:11 PM Thread Starter
I have a 96 model f350 five speed 7.3 .I went to change transmission fluid and then i found out someone else had tried also and stripped the head off the bolt where you refill the transmission. no wrench will fit filler bolt now .any ideals or is there another way to refill it??
cupper is offline
post #2 of 5 Old 04-15-2007, 09:58 PM
Mine had a bolt that was just about stripped so I just started filling it from the top where the shifter is. I can't remember the exact procedure for talking it apart but once you get your boot off around the stick, it's pretty easy to figure out. A tranny shop I went to one time said that he always did it this way because he could get a little more fluid in by bypassing the regular fill hole.
Mike
  • '99 F350 CC 180,000 miles so far. Edge Evolution programmer, AFE intake. 8" suspension lift, 3" body lift, 37" Hummer tires.
  • '96 F350 CC Dually KIA 663,000 miles at it's death
RopinandRidin is offline
post #3 of 5 Old 04-17-2007, 02:51 PM Thread Starter
Talking
Thanks for the info how much fluid do they hold??thanks again ropinandrydin
cupper is offline
post #4 of 5 Old 04-17-2007, 03:18 PM
Jeff_Northon's Avatar
Get a socket and pound it on. Undo. If that doesn't work, arc weld a socket onto the mungled plug. Undo, replace....
Jeff_Northon is offline
post #5 of 5 Old 04-21-2007, 05:06 PM
I actually can't remember right now. I'll have to look it up to see.
Mike
