how to lift 96 F250 4x4 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-01-2010, 02:08 AM Thread Starter
kpowerstroke's Avatar
Hey,
I was wondering how to raise my truck a little. Don't want much maybe 2 to 3 inches but I don't want to spend much. Is it my understanding that a body lift is not a good idea on a diesel?
kpowerstroke is offline
post #2 of 6 Old 02-01-2010, 07:44 AM
Chadahootchie's Avatar
body lift aren't recommended but I dont know why? The only problem is the you get that retarded gap between the body and frame. Also you have to becarful with heavy loads in the bed because the lift cant support it but that mainly only bed fulls of dirt.
1997 Ford F350 CC LB 4x4
2007 F350 axle/suspension swap
238/100 Full Force Stage 3 Injectors
H2E Turbo
Fully Built Trans with Triple Disc Billet
Tony Wildman Chip
Superduty IDM
5'' Straight Pipe 7'' custom sideways bed stack
Leveled on 37s
Chadahootchie is offline
post #3 of 6 Old 02-01-2010, 07:54 AM
Shaking the Bush Boss
CHUCK's Avatar
I wound up using 2" over springs from Custom Suspension
used 4'' (?) blocks in the rear.... ordered the frt suspesion drop brackets made by Rough Country from Top Gun Customz (sponser here on the ORG)
If this is the way you want to go....TKing has a set of the brkts he's tring to get rid of.
If I were to do it again...I'd try and find a donor f350 and do a straigt axle swap...
Chuck
CHUCK is offline
post #4 of 6 Old 02-01-2010, 08:05 AM Thread Starter
What size tires are you running?
post #5 of 6 Old 02-01-2010, 09:47 AM
CHUCK's Avatar
33 12.5 16.5 35s would probably fit...my frt bmper is spaced out about an 1nch
Chuck
CHUCK is offline
post #6 of 6 Old 02-01-2010, 10:06 AM
ryandamo's Avatar
i got a rough country suspension for like 400 bucks brand new on ebay when i lifted my truck. it was a rough ride but it got the job done. problem is on an f250 you have to drop the axle pivot brackets when you lift it or the alignment will be way off. i ended up swapping in a dana 60
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
