Replacing Tensioner Pulley - Page 2 - Ford Powerstroke Diesel Forum
  #11 (permalink)
Old 12-07-2012, 05:51 AM
Send a message via Yahoo to wickedford82
@Big Bird. Where can I get replacement bearings for the pulley's on my '99 Powerstroke?
Should I replace all three pulley bearings or just the two on the idler bracket?
Sent from my DROID RAZR using AutoGuide.Com Free App
  #12 (permalink)
Old 12-07-2012, 06:24 AM
Talking
WOW you wake up an OLD thread.
  #13 (permalink)
Old 12-07-2012, 06:36 AM
Yes, I guess I did lol.
I'm having issues with my pulley's now. They're making a loud whining noise. And I searched for an inexpensive way to replace them.
  #14 (permalink)
Old 12-07-2012, 07:19 AM
Arrow
I think you can get replacement bearings in any part store: NAPA, AZ, etc. Id change ALL of them.
Good luck.
  #15 (permalink)
Old 12-08-2012, 06:05 AM
Thanks.
I just got a reply from @Big Bird and said the same thing. But also said since there's that tension spring in it, it would probably be better to just replace the entire unit. NAPA has it for $80.00.
  #16 (permalink)
Old 12-08-2012, 08:08 AM
^^^^^ +1; putting a new bearing (or in your case, bearings in a tensioner with a worn spring is a complete waste of time. And the spring is as old as the bearings.
  #17 (permalink)
Old 12-08-2012, 03:04 PM
Thanks. I actually did end up replacing the entire unit. And when I was removing the old one, I noticed there was play in the tension by going the opposite direction from releasing the belt. So it is a good thing I replaced the whole thing. Also, out was the drive pulley that was bad. It only cost me $55.00+ tax through my friends commercial account at AutoZone.
  #18 (permalink)
Old 12-08-2012, 04:11 PM
Good luck.
I got some bearings that the NAPA guy said were the correct ones. They weren't sealed on either side. They didn't last very long at al before they seized. Tuns out they were pilot bearings meant to be greased. So be careful of where or from who you buy them from.
  #19 (permalink)
Old 12-09-2012, 12:29 PM
I would think by looking at the difference in the bearings you should have known something was wrong.
  #20 (permalink)
Old 12-10-2012, 04:04 AM
In my haste to fix my squealing belt I let optimism override my brain when he told me the catalog said they were the correct ones. Yep, I should'a known better.
