F350 Springs and Blocks - Ford Powerstroke Diesel Forum
Old 01-27-2010, 06:30 PM
I have a 250 and i have some F350 rear springs in my garage and wanted to get the F350 rear blocks also to give the rear alittle higher lift. My question is that if i put the 350 springs and blocks on will i have to shim my drive shaft or anything like that? Or will i just be able to put them on and be done? Is there anything else that goes along with putting them on. I know a couple guys have done this for the extra lift and hauling.
Let me know what you guys think
Thanks
Steve
Old 01-28-2010, 11:47 AM
Feedback Score: 5 reviews
Shouldn't need any shiming
Old 01-28-2010, 04:22 PM
you wont significantly raise it enough to cause any problems, the leaf springs, will set it at the right angle. make sure you use new u bolts when you swap it tho.
Old 01-28-2010, 05:18 PM
IIRC the rear springs are the same, just swap the blocks and use new ubolts
Old 01-29-2010, 02:55 AM
When you replace the rear springs will it ride a little smoother? I have a d60 that I will be installing as soon as the weather gets a little warmer - would it be a good idea to replace the rear springs as well?
Where did you find rear 350 springs and what do they usaully run $$?
Old 01-29-2010, 05:03 AM
You would think the F-350 springs would be a little stiffer,although my F-350 dually rides as good as any 150.
