Towing question - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-27-2010, 12:57 PM Thread Starter
bucwheat's Avatar
Towing question
Has anyone here towed an import behind there Diesel? I need to know if you tie down the steering wheel and if anything needs to be done concerning towing a front wheel drive import.
1997 F-350 CC Dually
Power Hungry performance chip. DIY air intake ,4" Diamond Eye exhaust, Trans temp gauge,Pyrometer gauge
10,000 Lb. Warn Winch, 1 million candle power auxilary lights,black heavy diamond plate bumper/brushguard
bucwheat is offline
post #2 of 15 Old 01-28-2010, 04:20 AM Thread Starter
bucwheat's Avatar
Good morning guys,can anyone help with this question?
bucwheat is offline
post #3 of 15 Old 01-28-2010, 05:35 AM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
How are you towing it? Dolly, trailer, rope?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #4 of 15 Old 01-28-2010, 08:48 AM Thread Starter
bucwheat's Avatar
Tow bar about 100 miles.
bucwheat is offline
post #5 of 15 Old 01-28-2010, 09:02 AM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
is the car an auto or manual trans?
BPS President
Jake is offline
post #6 of 15 Old 01-28-2010, 09:16 AM
Spanky88's Avatar
if it an auto itll cook the tranny. just puttin it in neutural isnt enough. unless maybe you leave it running to pump fluid thru it.
97 f250 extended cab longbed 4x4
electric fuel, 5"pipe, 6pos chip
d60 swap 3" lift 315s
fresh e4od-blown
Mike
Spanky88 is offline
post #7 of 15 Old 01-28-2010, 10:50 AM
ridiculously_necessary's Avatar
x2
i would trailer or dolly it if its an auto.
edit: or trailer if its a rear wheel for all wheel auto
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #8 of 15 Old 01-28-2010, 10:57 AM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
At least on a rear drive you can unhook the d-shaft.
BPS President
Jake is offline
post #9 of 15 Old 01-28-2010, 11:20 AM
cntryboy17's Avatar
Chain should do the trick o wait do you want it in one piece or not bahaha!
FB: Kyle Durflinger
E99 F350 CCSB 4x4, Auto, All stock for now..., straight piped
1990 f-250 7.3idi 4x4 5 speed
Originally Posted by oldtimer550 View Post
Chevrolet = French word for non-hetero buttsecks.
Originally Posted by 1tonpower View Post
the wait for the coverage articles in DP is like waiting for a girl to put out for the first time....
cntryboy17 is offline
post #10 of 15 Old 01-28-2010, 11:24 AM
I would never flat tow anything more 10 miles at most. Too many things to go wrong. Dolly at the least and preferably a trailer. Tie it down at all 4 corners. If you strap to the frame, pull it down hard enough to compress the suspension. If you tie to the axles, strap it down solid but it will bounce the whole way because the trailer springs and the towed vehicle springs will both be active. And make sure the trailer lights are good. The PSD will haul a car trailer like it's not there. If it's a 1/2 ton, be careful to get the load centered over the axles with 10% of the load as tongue weight. Pull the vehicle onto the trailer until the tonge drops about 1 1/2 - 2", you should be good. If it's a 3/4 or 1 ton, they are pretty forgiving as long as you have some decent tongue weight.
dave
97 F350 7.3 PSD CC 4X4
nepatternmaker is offline
