vent window?
OK somebody help me out please. My passenger side vent windows latch has been broken since I bought my truck but I cant find any type of a repair kit. The the latch itself is completely gone. I found one kit online a few months back and it came with no instructions and was missing pieces. Theres no way im the only one with this problem. Any ideas?
have you tried LMCtrucks.com?
Ya I have the book right here lol. Ill try again. They typically have EVERYTHING
good luck. May have to find one in the junk yard, and replace everything, hope not............
Ya im hoping to avoid that I was looking at it today and it looks like a PITA. I found one through LMC buts its the same thing I bought before- Latch a hollow piece of aluminum about an inch long by 1/4" in diameter and a little spring but it didnt make sense to me
Getting one from a wreck isn't bad. IIRC, there are two screws along the weatherstrip by the windshield, two nuts or bolts on the inner door skin. Pull the whole assembly out.
OK that should be easy then. Thanks guys
yeah i have pulled them before about a 10 min job total
Pull one out a cash for clunker. Costs $15 here. Comes with glass, frame and the whole bracket.
Make sure you get the correct side, and make sure it's a 92-96(97HD) truck. |
Just got done swapping the window with a 95 1/2 ton. Really easy like stated if anybody needs to do it. You can reach the spring/nut through the speaker hole in the door then just break the rivet and swap. Thanks again guys
