My New Filters - Ford Powerstroke Diesel Forum
Old 01-25-2010, 05:19 PM
Location: West Jordan UT, Currently working in Colo. Springs CO.
My New Filters
So while taking a pic for the ROTM, I thought I should take a few of my new filters I got from the Diesel Site, Here is the Tranny filter
and the coolant filter,
and this is the stupid plug I had to take out, I had to grind down an old 3/8" extension until it would fit.
Old 01-27-2010, 04:50 PM
lets try this again.
Old 01-27-2010, 05:04 PM
Rob Rob is offline
pretty cool bud!!!
Old 01-27-2010, 06:09 PM
good looking stuff!!! thats a good looking billet coolant block,, so they came from dieselsite.com?
Old 01-28-2010, 05:47 PM
yes they did,
Old 01-28-2010, 06:10 PM
Electrical Ogre
I had to do the same thing for the PITA 5/16" inside square plug. ...then months later I found a tool designed for it's removal.
Old 03-06-2010, 06:27 PM
Very Clean Install Work. ANd Bob's Billet work is tops.
I bought one of his billet thermostat housing units, with the 203 degree unit.
Where did you get the stainless braid trans lines?
Old 03-06-2010, 06:47 PM
Thank you. the stainless lines came with the kit.
Old 03-07-2010, 08:00 AM
I wanted to say that I also bought the stainless shut-off valves for the spin-on coolant filter system and I decided not to install the Valves because the opening was too restricted for my liking. Hooking the hose right up to the spin-filter housing gives me a better flow of coolant.
When I go to change the filter I use a spring Woodworking clamp to clamp the hoses on both sides and it works like a champ.
It adds about 1/4" to 3/8" round extra of coolant flow hooking the hose up direct to the spin/filter block.
Old 03-07-2010, 08:14 AM
Electrical Ogre
Any restriction in the valve wouldn't matter. The flow control orifice in the filter is about 1/8" diameter.
