10.25 into 10.5 - Ford Powerstroke Diesel Forum
Old 01-25-2010, 03:53 PM
10.25 into 10.5
Alright, I am thinking about swaping to superduty axles. Can I swap my 10.25 3.55 gears ino the 10.5 housing?
Old 01-25-2010, 04:09 PM
I believe that the only difference between the two is bigger bearing size in the 10.5" Given that I dont see why you wouldnt be able to swap your ring and pinion onto the new carrier
Old 01-25-2010, 04:12 PM
i know you can go from 10.5 to 10.25 not sure if you can go the other way but id guess yes just have to get the master install kit for it
Old 01-25-2010, 04:22 PM
I am looking at the randy's ring pinion and the gears say that thy fit either but i dont know about the originals. I thought that I read that they made them all the same now but that may just be new gears.
