Injector/Smoke Problems - Ford Powerstroke Diesel Forum
Old 04-06-2007, 03:29 PM
Could faulty injectors cause excess white smoke on a cold start up. Mine I am pretty sure are original, and thats alot of miles. Or is the motor just getting tired and time for an overhaul.
PS I installed a whole new glowplug system 2 months ago. ( Glowplugs, wires, relay)
Thanks
Old 04-06-2007, 09:54 PM
how cold is it where ur at?you could have a bad orings on the fuel side of the injector or maybe an injector hung opin.does it miss on startup?
i just changed all my glow plugs and relay and put stage 1s with new orings and mine still puffs a little on start up.
Old 04-07-2007, 10:20 AM
Have you ever changed out the injector o-rings? I agree with Matt that it might just be them.
Old 04-07-2007, 05:27 PM
i have never had the injectors out, im hoping its just them. I am gonna start saving for a rebuild in the far future thou. One more question any of you guys get a deep growling noise coming from the engine compartment when you accelerate with a load on the engine
Old 04-08-2007, 12:13 PM
the only time i get a growling noise is when im in one of the lower gears and not enough rpm.maybe your clutch,driveshaft.pinion angle change with heavy load?or even motor mounts.just a couple of things to check
Old 04-08-2007, 12:57 PM
BIG TRUCK, SMALL DRIVER
It may be the Fan clutch.
Old 04-08-2007, 02:39 PM
i know my clutch is going out, soon as my taxes come back thats where that money is going. Sound seems to be coming from further up front than that thou
Old 04-08-2007, 03:38 PM
International Threat
Matt I just want to take this oppurtunity to say your truck is EFFIN awesome... it's the first time I've seen it!
Old 04-08-2007, 03:41 PM
Desert Shield/Storm Vet
Wow I just checked out matts garage! You can play twister in that thing!!! Sweet truck!
Old 04-08-2007, 07:17 PM
A new set of o-rings isn't too much money and the work isn't tough at all, just in case it gets any worse.
