Ball Joint Replacement - Ford Powerstroke Diesel Forum
Old 01-22-2010, 08:54 PM
Gotta replace the driver side upper and lower ball joints on my 1996 250 4wd. Got started this evening and took apart the brakes, hub locker and got down to where the spindle nut is and apparently gotta have some special socket i was unaware of beforehand. What exactly is this tool called? Just a spindle nut socket? Also, anybody have suggestions on other issues i may run into when i get back at it in the mornin? Thanks for the help
Old 01-22-2010, 08:58 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
I took it off with some large screw drivers and gentle force. I am serious about the gentle part.
Old 01-22-2010, 09:02 PM
well i gave it a go with the screw driver for a minute and it seems pretty tight and i was a little worried but messin somethin up in there. also, are there different sizes of spindle nut sockets? i'm assuming yes. in which case, which size am i lookin for?
Old 01-23-2010, 06:05 AM
your looking for a dana 50 or 60 spindle socket it the real big one with 4 prongs on the end of it. You can get them at most parts stores but make sure it the right one because the one you need is hard to find in my area.
Old 01-23-2010, 03:03 PM
Got mine from the snap on guy. It has a wierd moon shape on the inside around the socket.think it set me back like 30 bucks. They will definitely have what you need.I'll try to post ya a pic
Old 01-23-2010, 03:06 PM
wriott
Guest
Posts: n/a
i got mine a carquest
Old 01-23-2010, 05:32 PM
do you have auto hubs or manual? auto zone has them for like 6 bucks
Old 01-23-2010, 05:58 PM
Mine is a K D part #3246
Old 01-24-2010, 05:49 PM
well ended up findin the tool at autozone. set me back 20 bucks. but after some trouble i finally got the balls changed out
