SD electric fuel system on an OBS - Ford Powerstroke Diesel Forum
Old 01-21-2010, 03:10 PM
im sure there is a right up some where on here, but i lazy!! so wat all do i need for a SD to do the mod????? got a guy on hold waitin to see wat all i need!!!
Old 01-21-2010, 03:15 PM
I have it bookmarked somewhere, hang on...
sweeet thanx bro
Old 01-21-2010, 03:19 PM
Electric fuel system conversion - Powerstroke Nation
That is how one person did it, you can really do your own thing with it
Old 01-21-2010, 03:26 PM
ya i was just trying to find out wat all i need like a the pump and the two fuel housing up top? wat elce
Old 01-22-2010, 07:13 AM
here is a partial overview of my upcoming project:
1. Remove FB
2. remove mechanical pump
3. New FPR with a re-routed return
4. Electric pump
5. spin on filter
Process: tank > filter > pump > split behind the motor > into heads > out of heads and join to common > FPR and return.
i took a brief look at the PSN link, it will end up looking somewhat like that.
edit: not that i take the time to read the PSN thread, that looks almost exactly what im going to do. very nice thread!
Old 01-22-2010, 06:20 PM
so do i just need the pump or wat
Old 01-25-2010, 08:01 AM
youll need the pump, wiring harness, FPR and any potential lines for your setup. when i say that look things over in your truck and see hwo your goign to plumb the new pump. then youll have an idea what you'll need for lines.
Old 01-29-2010, 09:33 PM
At what point in converting in converting to electric fuel, injectors, etc. etc. should you do the 17* HPOP SD upgrade? Also if the SD pump is mounted above the tanks say 12-18", will think affect the pump performance, life, etc. ? Thanks ahead of time!
Old 02-01-2010, 05:57 AM
general consensus is more with injectors than pump. its reccomended with stage ones to use them to their full potential but pretty much required for stage II's. i would think it would hurt the pump too much, IMO, i would just put it in the framerail.
