changed 1 injector, oil went into cylinder..... HYDROLOCKED???? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-20-2010, 04:13 PM Thread Starter
so i replaced 1 injector and went to fire it up and the starter bined up like it hydrolocked from the oil going into the cylinder.so i let it sit for a min, and turned it over again and it sputtered a little bit then fired up and was running rough. so i turned it off again. if it hydrolocked a little bit, do you think i could of bent a rod?? i hear that the injector takes a while to fill w/ oil. and i needed a valve cover gasket becuase 1 side shorted and melted so the truck sits.
do you think that i could of bent a rod. i hear these motors are pretty strong. it is just worrying me a little bit. THANKS FOR YOUR HELP!
roachedstang is offline
post #2 of 20 Old 01-20-2010, 04:19 PM
Quoted: 5 Post(s)
it takes a whle to get hte air out of the HPOP rails and such, but yes, hydro locking can bend rods.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 20 Old 01-20-2010, 04:23 PM
shaking things up
jethro's Avatar
not good i would look into it and check it out well before going any farther
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #4 of 20 Old 01-20-2010, 04:32 PM Thread Starter
what should i check for, im letting the oil drain out of the cylinder tonight, and the new harness will b in tomorrow, how will i know i bent a rod?? and is there a chance that it is not bent. it only bound up while cranking, and i stopped till it fired up, but i dont think that injector is firing, it literally ran for 5 sec before i shut it down.
post #5 of 20 Old 01-20-2010, 04:39 PM
shaking things up
jethro's Avatar
1 sec is enough to do damage and i am not sure how to check without tearing the motor down maybe someone else will chime in with more knowledge
389.14 HP 726.00 TQ
3 in DP
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
jethro is offline
post #6 of 20 Old 01-20-2010, 04:52 PM Thread Starter
yes someone help this is driving me nuts.... ive talked to a few buddies and they said that the motors are pretty stout. so chances are that nothing happened.. woulnt you blow a ring before you bend a rod.
post #7 of 20 Old 01-20-2010, 04:57 PM Thread Starter
all i did was change an injector, i mean come on! and all of the injectors prob had a little oil in them becuase i just changed all of the glow plugs also.
post #8 of 20 Old 01-20-2010, 04:58 PM
ajpu1983's Avatar
Yeah I would say you'll be alright. Did you say a harness is melted on there?? I would fix that first. And run it down the road to get all the air out of the oil rail.
ajpu1983 is offline
post #9 of 20 Old 01-20-2010, 05:10 PM
Pull the glow plug for that cylinder and crank the engine over to clear the cyltinder of oil and fuel. Then try again
1997 F350 4x4 CC dually,3 inch exhaust,DIY intake,Edge tuner,HD E4OD trans rebuild.
kidmogster is offline
post #10 of 20 Old 01-20-2010, 07:37 PM
97psd4x4's Avatar
do what kidmgster said only way to free it up. better have some good batteries
theres a allen wrench plug in the head toward the front of the block to drain the oil. prevents it from draining,its what ford techs do when they change out the orings.now if ur changing the whole injector then just as soon as u get it out oput the other in. also get a crows foot works the best on pulling out.
1997 F250 7.3L XLT 4x4 ext. cab Lb
Tw 6 position 33" Mickey's
Guage Pod 20'' Scorpion's
'01 IDM Leveling Springs
Fpr Shim '08 Console
5'' Diamond Eye w/Mbrp downpipe
Built Transmission
97psd4x4 is offline
