Wanted 1996-1997 PSD 4x4!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-19-2010, 08:38 PM Thread Starter
Hey guys, I'm looking to find a PSD 96-97 f250 or f350 looking for a extended cab and has to be 4x4. I don't really care about mileage as long as it's not like 300k plus. My main concern is the body I don't want a rusted out pos, but I'm not looking for a perfect rust free body either, something that can be fixed with some TLC. I only have no more than $4000 budget cause what I have left would need to be used to fix what would need to be fixed.
I live in Dearborn Michigan and I would travel probably about up to 100 miles away to pick up. But if you guys have one or know someone let me know.
Bigjoe!
BigjoeC1995 is offline
post #2 of 5 Old 01-19-2010, 10:26 PM
strokin94's Avatar
to the org. I'd try craigslist or here on the org. Goodluck with the search.
NEW TRUCK
1997 F-250 Ext Cab 7.3 4x4 Auto w/245k
MODS
Stock
REGRETED SELLING
1994.5 F-250 Reg Cab 7.3 4x4 5-Speed w/209K
MODS
Downpipe,Intake, Exhaust, Guages,TS Chip, Skyjacker Lift, BDP 1.0 Housing
TRADED IN
1995 Ram 2500 Ext Cab CTD 4x2 swapped nv4500 w/192k
MODS
BHAF, Downpipe, Exhaust, Guages, Silencer Ring MIA, Adjustable Boost Valve, AFC FF, 100 Plate FF, Starwheel Tuned, AFC , 4K GSK, 2095 Rack Plug
strokin94 is offline
post #3 of 5 Old 01-20-2010, 01:44 PM
Gruss's Avatar
This is my buddies truck near Pittsburgh PA
96 Crew cab 8' bed 4x4 5 speed PA
time has come to move on.
96 Power Stroke 4x4 5 speed 4x4 Crew cab 8' bed
260k.
modifications
baby swamp injectors
custom electric fuel system
intercooler
pryo, boost , fuel pressure gauges on a pillar
Dp tuner custom 4 pos chip
3" downpipe to 4" exhaust
hX line
reman turbo
dual tensioner mod
big air filter mod
ccv reroute
Turbo life saver cool down module
3.73 gears limited slip rear
35" tires on american racing wheels.
3" body lift
billet grille
1.5" correct track rear wheel spacers
am/fm cd player
front add a leaf
monroe reflex shocks
steering stabilizer
10" drop bumper
reciever hitch
in past 5yrs and since 230k have replaced
clutch
ball joints
front axle joint
rear ujoints
front drive shaft ujoints
new rear brakes
rear end bearings (did when I did the rear gears)
front bearings
front spring bushings.
steering shaft
drag link
glow plugs
glow plug relay
rebuilt oil cooler
1 head gasket(had to pull head to remove POS autolite glow plug)
water pump, hoses, thermostat
block heater and coed
injectors (put bigger ones in)
im shure there is more
truck is tan with black bedliner from the trim strip down
had to fix some rust on the bottoms of the doors and the rockers.
and replace the driver fender. the only rust left is on the pass side fender above the trim
there is a few dents and dings here and there, and needs a new mirror on the pass side.
you can also see where the decals where on the back door from previous it ya look hard enough
there is ahole in the bed where I put the stacks in, and some hole through it where I had the aux fuel tank plumbed.
I have a bedliner for the truck though.
inside it has bench seats the front has power lumbar
rear seat is wore on the driver side (swapped seats frot to rear)
the dr side rear power door lock is not working,(needs new actuator)
also a crack on the switch panel on the driver door.
No carpet, has factory rubber mat.
Truck is mech excellant, with a little touch up it would be perfect.
Dyno proven 349HP at the wheels.
asking $8000.00 or offer. which I believe is fair.
may be open to a partial trade for a camper, but mainly want cash
I will get some picts as soon as the snow melts
picts and more here
96 power stroke pictures from trucks photos on webshots
"If you want smoke, work for it. These guys did" JJFLASH
Stormtrooper:: 1997 F-350 CC SRW PSD XLT 4X4: Baby Swamps, Wildman 4 pos chip, 120V IDM, SD Intercooler,BTS E4OD, RSK, CCV mod, shimmed FPR, DIY 6637 air filter, triple pillar pod with Isspro gauges, 4" MBRP exhaust, SD dual tensioner,
Gruss is offline
post #4 of 5 Old 01-20-2010, 02:20 PM
IHwelk49's Avatar
well if you had more in your budget I'd sell ya mine. I don't advertise it, but hey everything is for sale if the price is right
96 F350 Crew Cab
Tymar Intake-Intercooler-Beans Dom 66 turbo-
5" stacks exhaust-Beans Stage II's-TW chip 17* HPOPSD Electric Fuel
4" lift 18" Eagle alloys
Fully Built Auto
IHwelk49 is offline
post #5 of 5 Old 01-20-2010, 03:06 PM
Send a message via AIM to kx592
Hey mines for sale..97 exten 8ft 4wheel...188K new everything on the motor and such...asking 7500 but will do 7, body has minimul rust...located in asbury 08802 check out ebay if you want details and pictures...
1997 7.3 extended cab 8ft.
4" straight piped
DIY intake- 6637 filter
178K on the dash
Boost, PYRO, Trans temp gauges (auto meter)
33" nittos on stock height
kx592 is offline
