Changing rotors and pads... - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-18-2010, 05:13 PM Thread Starter
Well, I'm not, but I'm having someone do it. I bought the front rotors and pads and I want to know if there is anything else necessary that I should buy. I'm thinking I should buy some brake fluid, which type?
I know there are some brake kits, but I would prefer to use the existing parts. Any advice?
1997 F250 2WD Crewcab Powerstroke
All Stock
230,000 miles
tftimm is offline
post #2 of 2 Old 01-18-2010, 05:35 PM
ryandamo's Avatar
dot 3 for brake fluid, that should be it, might have to replace caliper too if its freezing up but its probably not, just get ready to buy on if the person doing it for you tells you you need it.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
