HELP with banjo bolt - Ford Powerstroke Diesel Forum
Old 01-14-2010, 02:29 PM
Please help me with any ideas as how to get the banjo bolt started!!!!i have tried everything i can think of but just cant get the threads started. Even pulled fuel pump back out and started bolt just to make sure the pump wasnt messed up. Didnt have any trouble starting it with the pump out!!! Please help with any ideas!!!!!!! Asmy truck is down till i get this fixed!!
Old 01-14-2010, 02:50 PM
When I put a new lift pump in my OBS, I had a little trouble getting it started but more trouble getting it to go straight. After having to redo the threads in the pump numerous times, I, very carefully, slightly moved the fuel line fitting hoping to get it lined up better and it went right in. It took many attempts to get it adjusted correctly but I finally got it.
Good Luck
Old 01-14-2010, 02:52 PM
When I did mine i sandwiched that second washer between the fuel fitting and pump and put pressure on the fuel fitting to keep it there. The bolt started right up but if it doesn't just slide the fuel fitting around on the hole (to keep the washer in). It just takes patience. Luckily mine went right in...
Old 01-14-2010, 05:59 PM
I tightened down the pump then threaded that damn nut in there. Hope that works for you too. Good luck bud.
Old 01-15-2010, 03:26 PM
Did you loosen up the lines that go to the rear of the heads? I had to do that on mine b/c mine didn't want to line up right and I didn't want to mess it up either.
Old 01-15-2010, 04:15 PM
Put a washer on the banjo...slide it through the collor...at this point i found it easier to hold the banjo with a retreivel magnet....put the second washer on ...then pull the banjo into place with a "hook" tool....then its a matter of many small turns with an 1 1/4...Can be a PITA...Greg
Old 01-15-2010, 04:16 PM
Leave the pump loose a few threads....so it has a little movement.
