exhaust smell in cab with heat running - Ford Powerstroke Diesel Forum
Old 01-10-2010, 11:11 AM
Anyone else have this problem? I can smell it when I'm stopped at a red light or if I start her up in the morning for work and turn on heat befor I get in to leave. Any thoughts? Thanks Josh
Old 01-10-2010, 12:09 PM
tjl tjl is offline
Check your up pipes. They may be leaking. Look for soot around the connections, also check where your down pipe connects to the turbo. That clamp can come loose also.
Old 01-10-2010, 12:41 PM
Send a message via AIM to ford_trck
I will agree 100% with what he said
Old 01-14-2010, 06:25 AM
i have this problem to. let me know if you get it solved i dont have a leak anywhere
Old 01-14-2010, 07:45 AM
yeah i get that too
Old 01-14-2010, 08:16 AM
Mine always has done that,what I do is keep the blower off until I get going forward that way I'm not backing through my exhaust.
Old 01-17-2010, 07:43 AM
Had that one too, the fumes in the cabin were killing me. Check the firewall behind the turbo. If you see black soot on it, you need to untie the clamp and realign the turbo and the pipe.
Old 01-17-2010, 09:26 AM
The exhaust manifolds may have warped. Gotta take a close look at the whole deal to narrow it down. May be in more than one area.
