Beans D-66 turbo? - Ford Powerstroke Diesel Forum
Old 01-09-2010, 11:57 AM
Beans D-66 turbo?
I have been looking at and thinking about upgrading my turbo to one of these. My question is what are the real differences with this turbo. I mean larger wheel, intake and exhaust? How much larger is the wheel? I have a 97 CC 4X4. Swamps Diesel stg.1 injectors and 6-pos. chip. 3" dp straight exhaust, DIY intake.
Old 01-09-2010, 12:11 PM
Real Men Love Jesus! <><
It flows 30% more air. When I put mine on my SD, I instantly felt the power increase! I love it. I dont know how much bigger it is over stock as in millimeters or anything.
your setup with that turbo should work good!
Old 01-09-2010, 12:39 PM
Forgot to put that I will also be adding a IC when the weather warms up here alittle. I am really wanting to know the wheel differences between the two.
Old 01-09-2010, 12:41 PM
i think the stocker is a 58 or 60 mm wheel, while the d66 has a 66mm wheel.
Old 01-09-2010, 01:21 PM
Thanks for the info. Do they make the wheel themselves?
Old 01-09-2010, 10:41 PM
The D66 is a great upgrade. If you do go with it have your tuner re-burn your chip for the mod.
Old 01-10-2010, 03:19 PM
I know it is a great upgrade. I mainly want to know what the technical differences between the D-66 and stock are. Tried a search on here and found some great testimonies for it but not what the differences are.
Old 01-10-2010, 04:25 PM
it has a 1.0 housing on the exhaust, a 66mm wheel, and bigger comp housing. what other tech specs you need? you want actual numbers? call river city turbo. they build it.
Old 01-10-2010, 04:47 PM
615-563-7800
