Missing until under load - Ford Powerstroke Diesel Forum
Old 01-09-2010, 06:01 AM
Mabey its just me but it seems as though my truck has a miss coming from the rear of the drivers bank until I get a load and build at least 5-8psi of boost.
I know I have heard others that sound the same but it just dosent seem right. It will get a slight chugging at idle as well. But this does not happen all the time.
Mabey CPS or a UVC harness?
Old 01-15-2010, 09:39 AM
I seem to have a similar problem, slight miss under light throttle, once you hit the throttle a bit harder its fine. Have you had any luck locating the problem? Keep me updated.
Old 01-16-2010, 05:23 PM
maybe the "miss" is an up-pipe leak.mine will chug and blow black smoke until the turbo spools.mine almost feels like its chokin abit until it spools.i believe my problem to be up-pipe leaks,could be your problem as well.
Old 01-16-2010, 06:27 PM
That has been somthing that I have considered but I cannot ever find any leaks. no smoke deposits.
Old 01-17-2010, 07:06 AM
Send a message via AIM to kx592
I noticed that lately but only around 1200-1350 rpm..Just give little more throttle and clears up...truck doesn't jolt of feel different but I can hear it if im looking for it.
Old 01-20-2010, 09:08 AM
I was having a similar problem. I checked everything and couldn't figure out the problem. I noticed my dipstick tube was leaking AGAIN. It was low on oil so it wouldn't fire the injectors like it should.
Old 04-15-2010, 07:22 PM
so then being a little low on oil was the cause of the problem? Mines doin the same thing, slight miss and occasional chugging at low rpm or cruising speed.
Old 04-15-2010, 09:52 PM
Ive been told that mine was the uvch. Got to get the money to replace mine. Hopefully that will fix the problem. A friend of mine had the same problem and he changed his uvch and he said it fixed it. Hope this help out.
