runs rough and shuts off - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-07-2010, 06:36 PM Thread Starter
i have a 97 superduty 7.3, driving down the road one day there was a lil grinding noise and lack of power.. in about 2 miles it went away.. then a few days later there was no power at all it barely idled..
so i plugged in with scan too and got a ebp circuit failed code, went to lacal navistar shop got a new sensor and camp.. put parts on truck and it ran for about 5 mins and shut off.. i figured it was time for new glow plugs and harness, when i started on that come to find out the old under the cover harness was burnt so i went to local salvage yard and got new un melted engine harness,
still runs for few mins and dies, got a know goood used high pressure pump nothing, replace ipr, fuel pressure regulator and just getting tired of putting parts on it.. any suggestions??????
new glow plugs
valve cover harness
engine harness
high pressure pump
pressure regulating valve
no codes and good icp
what am i missing?
nateduty is offline
post #2 of 3 Old 01-07-2010, 06:41 PM
Nitro41's Avatar
wiggle the icp connector that plugs into the actuall sensor. that was the problem with mine. i would wiggle or shift it and the truck would stall or idle super rough. i put a new connector on it, and it runs better then ever
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #3 of 3 Old 01-08-2010, 07:09 AM
ridiculously_necessary's Avatar
is it the icp or the ipr that you can just unplug to diagnose? somoen will hopefully say and then give that a try.
also do you have fuel in your bowl after it shuts off? have you checked your fuel pressure?
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
