Cheap Injector O Rings - Failure - Ford Powerstroke Diesel Forum
Old 01-07-2010, 06:13 PM
I replaced the injector o rings on my 1997 F250 7.3L two years ago when I bought the truck. The injector cups were cracked and since I had the injectors out I had to replace the seals. I bought the injector o-ring service kit from Napa. It came with all the seals to service two injectors. Everything was fine until a month ago. I started going through oil like crazy. 8 quarts in 10 miles. Something was wrong.
I opened the fuel filter and it was covered in oil. I knew the injector seals were bad, so I pulled them out. When I got the injectors out most of the o rings had shrunk and were very brittle. A few o rings were torn with pieces hanging off of them.
I replaced the old seals with ones from Ford. They were more expensive than the ones from Napa, but the quality was much better. I really regret not getting the seals from Ford in the first place, but I figured the Napa ones would be of good quality. I guess you get what you pay for. It would have saved me a lot of aggravation in terms of having to do a job twice.
Since the first time I did the seals, I have heard of a few other people say to stay away from aftermarket injector seals because of premature failure. Maybe this will help someone out, I'm not saying this will definitely happen, but I would not want to do this job again. For reference the Napa rings only lasted about 3000 miles. The truck has just over 165K right now.
Old 01-07-2010, 06:39 PM
wow, thanks for the heads up. I just replaced mine. they were starting to show signs of wear, but i didnt have enormous oil consumption. atleast it was a easy fix for ya
Old 01-08-2010, 07:12 AM
thanks for the info!
Old 01-08-2010, 12:20 PM
i bought mine from and Internatial dealer like 16 bucks a piece.
Didnt want to mess things up.
Old 01-08-2010, 12:23 PM
shaking things up
how hard in injector cups to replace and how do you know if they are bad?
Old 01-08-2010, 12:32 PM
not fun at all to replace.........you'd have oil in your coolant
Old 01-08-2010, 12:42 PM
I have 200k on my 03, I have to swap some glowplugs, is it worth doing the orings while im under there?
Old 01-08-2010, 12:45 PM
shaking things up
ok so orings will cause it to burn oil not the cups?
Old 01-08-2010, 12:46 PM
shaking things up
is everything stock? if so then i might if you have the scratch to do it
Old 01-08-2010, 01:49 PM
all stock except for a 50hp diablo chip. Runs like new.
