re-gearing Q's - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-06-2010, 09:26 AM Thread Starter
19Dscout's Avatar
Send a message via Yahoo to 19Dscout Send a message via Skype™ to 19Dscout
re-gearing Q's
Hey everyone, I have 3.55's in my truck, 5-speed, with 33's now. I want to do a 6 inch lift, (probably deaver springs) or (national spring co) and i want to run 37'' bfg a/t's on the stock 16'' alum. wheels. My question is do you think i will beable to pull 37's ok with the gears, i really dont want to change them out to 4.10's or 4.56 i would like to just keep the 3.55's so any info would help alot thanks guys let me know your op.
anthony
97 f-350
58k
5 speed, 3.55s
3'' dp, 4in straight piped,
fpr shim,
19Dscout is offline
post #2 of 4 Old 01-06-2010, 02:43 PM
Chadahootchie's Avatar
you should be fine I have 4.10 and 38's on my old with an auto and it did fine and my mud truck has 4.56 and 44's with a 4 speed and does good. Hope that helps
1997 Ford F350 CC LB 4x4
2007 F350 axle/suspension swap
238/100 Full Force Stage 3 Injectors
H2E Turbo
Fully Built Trans with Triple Disc Billet
Tony Wildman Chip
Superduty IDM
5'' Straight Pipe 7'' custom sideways bed stack
Leveled on 37s
Chadahootchie is offline
post #3 of 4 Old 01-06-2010, 11:26 PM Thread Starter
19Dscout's Avatar
Hey thanks for the info, i thought that 3.55's would be enough, just wanted some peoples opinion on the matter, thanks for the input.
97 f-350
58k
5 speed, 3.55s
fpr shim,
19Dscout is offline
post #4 of 4 Old 01-06-2010, 11:47 PM
Powerstroke W/smoke's Avatar
they'll work but you'll be putting more stress on other components. getting gears is a precautionary measure i've been told lol
Sold!2001 F-350Lariat Lifted 7.3L CC, 5" Straight Pipe, DIY Intake, Foil-Delete, 6 pos chip, CCV Bypass, 37" Toyo MT, Gauges, Blacked out, 07 Harley Front-End.
SOLD!2006 F-250Amarillo 6.0L CC, 4" Straight Pipe, SCT-II
STOLEN ,2001 F-350Lariat 7.3L CC, 6pos chip, 4" Banks Straight-Pipe, Banks Comp Wheel, Custom Lighting, Foil-Delete, Intake.
Powerstroke W/smoke is offline
