1996 7.3 Turbo Question - Ford Powerstroke Diesel Forum
Old 01-05-2010, 11:01 AM
Question 1996 7.3 Turbo Question
I have a stock 7.3L in 1996 F 350. The problem is I seem to have to much crankcase pressure. My mechanic said there probably a seal going bad in the turbo and is leaking pressure into the crankcase. Truck has 160K on the clock and runs great, burns little oil. But seems to blow back out of the dip stick and filler tube. Should I replace turbo? Don't want to waste 1300.00 bucks.
Old 01-05-2010, 11:16 AM
go here: 1996 7.3L Turbo Problem
Old 01-05-2010, 11:21 AM
i would consider getting a new mechanic, since this is virtually impossible the only thing a turbo can do is suck pressure out of the crankcase. what kind of air filter are you using? you could have dusted your engine and have worn out piston rings
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
No, thats blow-by. It's normal for the most part. I dont think there's a truck out there that has zero blow-by
Old 01-05-2010, 11:25 AM
yea a little is normal, sorry i thought he said that it was blowing the dipstick tube out of the hole, which ive seen happen on these trucks that get dusted
