Transmission flush
I finished installing a Tru Cool transmission cooler on my 2000 F250 last night. After that, I flushed the transmission by disconnecting the return line to a 3/8" clear tube going into a container.
I was expecting to see six to seven quarts of trannie fluid coming out before bubble showing up and having to turn off engine and added new oil to the transmission. Only four quarts coming out of the line before bubbles showing up in the line and I had to stop engine to refill. That happened four times before I added a total of 20 quarts. The question here is WHY only four instead of six quarts came out each time? does that mean my transmission oil pan is smaller than it is supposed to? Last edited by mas360; 12-30-2009 at 09:00 AM. |
No. lol. Was the trans cold? You may need to give it a tiny bit of pedal to get the pump going. for a routine flush I go to Jiffy lube and have them power flush it. doesn't cost much more than buying the 17 qts your self. They use penzoil multi purpose heavy duty atf. lowered my temps and improved trans behavior. Been running it for a few k now. Still smells good.
I used to take my vehicles to lube shop, but now I'd rather do it myself as I am not sure of what they put in my transmission and if their flush machine is properly cleaned after each job. The dollar saving is not the issue. It costs $60 to do myself versus $100 at the shop.
My next door neighbor has a Nissan Murano like mine. He took it to a lube shop and these people put regular ATF into it. His transmission failed less than 40 miles later. The Murano has a CVT (Continuously Variable Transmission) and it uses a special oil, not regular ATF or Mercon V. It costs him 6.5K to replace it. Nissan states clearly that if transmission fails due to using wrong trannie oil, that voids warranty. He is still in legal dispute against the shop. No, the procedure is to leave engine running at idle to pump fluid out of trannie. Last edited by mas360; 12-30-2009 at 09:08 AM. |
dont use mercon V. thats all imma say.
u have to replace a certin seal to run synthetic. When i had mine rebuilt the guy told me he upgraded it and i saw it too. Now im running Mobile 1 Synthetic ATF. Dont worry i flushed the cooler lines competyl with the stuff in the can then blew it out
