CCV Mod - Ford Powerstroke Diesel Forum
Old 12-27-2009, 03:35 PM
CCV Mod
I recently installed a intercooler on my 95 and was wandering what was the best mod on the crank case vent hose to keep it out of the intercooler now.Any help will be greatly appreciated.Thanks
Old 12-27-2009, 03:39 PM
I would get this kit. I have it on mine...CCV Mod
Old 12-27-2009, 03:46 PM
Thanks for the info.Looks like that is the best and easy way to go.Thanks again!!
Old 12-27-2009, 03:47 PM
Yep its a great kit.
Old 12-27-2009, 04:23 PM
Location: lake county california, 2hrs north of san francisco
I would just go to the local parts store and get 10' of 5/8" heater hose and a 90 degree hose fitting and build your own. Thats what i have done to mine and a couple other trucks. Its a lot cheaper. You just have to unscrew the little box on your vaulve cover and rotate it to get clearance from the intake tube.
Old 12-27-2009, 04:25 PM
I wounder if it will act like sucking on a hose and suck your oil out if you tap into your exhaust with this...
Old 12-27-2009, 04:26 PM
Ive heard that it can cause a lot of oil to leak. If you do it the hose way then you have to deal with the smoke and smell...
Old 12-27-2009, 04:27 PM
yup, thats the mod. just turn that dogbox on top of the valve cover around and then do whatever you like with it after that, but a kit, just run it out the back, I have even seen it dumped into the main exhaust
Old 12-27-2009, 04:37 PM
I think I'm just gonna tap it into the exhaust under the cab. if it leaks it leaks. But it will be away from me and someone elses problem when I stomp on it!!..
I'll let ya know how it goes..
Old 12-27-2009, 04:55 PM
I say go for the one in the link.
