Lifting on the cheap penny for you thoughts
Ok I have figured out that I want to do a shakle flip on the rear but i am also going to add another shakle bracket on all the outer corners for more travel. Now the front I am going to cut the swing arm brackets horizontaly and add what ever more material that i have to to make it level. I am not sure how much at this time I am going to end up with my goal is to be able to put some 37 12.50 R16.5s on it. Lastly I want to get some springs off of something or off the rear of this truck so they arnt bowed backwards.
So please give your thoughts and advice, I figure most of this can be gotten for about 100-150 at a wreaking yard. thank you all much! |
Just so you know you can fit the 36x12.50x16.5s stock. I did it. It will rub in the front but not bad.
thanks for the info bump
bumps
im not sure i understand anything u just said.
whats with the extra brackets???? |
