testing glow plugs question
Hi. I've read you can test your glow plugs with just a test light on the valve cover electrical connection but can someone please remind me exactly where to attach the test light?... 12v or ground? I'm at a hotel and don't have a volt meter but I do have a test light. My gpr works fine. Any help would be great. Thank you.
Are you trying to test the glow plugs at the UVCH connector in the gasket with the valley harness pulled out? What you will want to do then is connect the gator clip/wire to the (+) of the battery, and touch the probe of the light to the pin in the connector. Bad thing is though, if a wire shorted to a rocker, etc, it will still light the tester.
