another death wobble - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-25-2009, 05:19 PM Thread Starter
Tsgs69400's Avatar
My friend has a 96 250 with a d60 kingpin conversion. he is getting a bad case of DW around 45-55 mph and is running 285/75/16's
He initally got it when he put his 36' tires on though he is now getting it with the 285's.
He suspects the steering stabilizer though I don't think that's the root issue.
Steering is tight. Havent checked toe yet.
Thad
2008 f-350 CCSB 4x4 6.4 Lariat Spartan Tuned, MBRP Duals, S&B intake, egr delete, ccv delete,custom coolant bypass, RF amps, Infinity Component Spkrs, Pioneer Shallow Sub, 13.9sec best
1996 f-250 Extended cab Short bed 4x4 7.3 5-spd, D60, Diamond Eye4" duals, DP Tuner, Stg 1 Injectors, DIY Intake, Custom Regulated Return Fuel System, Adrenaline,billet ww,Comp 910 springs, D66 Turbo, 6.0 Intercooler, SD rear springs,Custom trac bars, Truetrac diff.
Tsgs69400 is offline
post #2 of 5 Old 12-25-2009, 05:28 PM
ryandamo's Avatar
does he have a track bar attached and is it parallel with the drag link? also are the bushings good at both ends?
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #3 of 5 Old 12-25-2009, 05:39 PM
I would second to check the track bar make sure that bushings and mounts are good and tight. Do you have a lift on the swapped D60? Cause if you do the mounting bracket will not line up right with the mounting wholes. Then you would need to call a lift kit company to see if they have a bracket that matches your lift height. If there is no lift then all should match up just right. I did the swap my self last year but I used a D60 off of a 96 F350 so it was a complete match for all parts, even the brakes. Please me know if you need any help. Merry Christmas
Nick is offline
post #4 of 5 Old 12-25-2009, 05:45 PM Thread Starter
Tsgs69400's Avatar
I am not 100% on the trac bar but there is a possibility that he did not even install it at all. He was telling me of how lots of people are running around without it. As far as the springs he installed a couple add a leafs. No particular kit. I told him that the tracbar was important but idk if he took the time or not.
The interesting part is that he has been running the same setup for 9 months without any issue.
Thad
post #5 of 5 Old 12-26-2009, 05:27 AM
WOW thats cool he ran nine months without it. The track bar bracket will not work correctly unless he gets a drop bracket for the install. If he installs it without the drop bracket then it will push the axle out an inch up to 3 inchs out and it will track funny down the road. NAPA should be able to find a drop bracket. Just let them know the amount of lift you have and they should be able to find one. If that does work install that bracket in the factory location then buy and adjustable trackbar. it does the same thing just from a different perspective.
Nick is offline
