changing injector solenoid - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-23-2009, 08:46 PM Thread Starter
Nitro41's Avatar
I got my stage 1's in the mail and 1 of them had a busted elctrical connector. I put them all in and kinda just plugged the injector in. truck started up, and ran then after about 20 minutes, it went into a dead miss. very rhythmic, so I figure that connector let go (hole 6)
I got a new solenoid in the mail tonight. can I just take the 4 torx screws out of the top and change the sloenoid without taking the entire injector body out?
also, is it typical for the truck to run with a little random misses after the injector install, like first 20 minutes
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #2 of 3 Old 12-23-2009, 09:46 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 113 Post(s)
Yes, you can swap the soleniod without injector removal. I've gone as far as removing an injector poppet to extracate a broken armature screw with the injector on the engine. Place rags around the injector so if you drop something, it won't fall somewhere bad. You will have some missing until the air is out of the oil and fuel rails.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #3 of 3 Old 12-23-2009, 10:37 PM
Tony V's Avatar
yeah it will run funny
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
