Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L General Powerstroke Discussion
Old 03-15-2006, 09:38 AM
keane6750 keane6750 is offline
Boost leak?
Hey guys.. I got the boost gauge in.. it was actually pretty easy. But my guage flutters when it gets near 15psi. I'm assuming that there must be a leak in the line. It doesn'tsound like it's leaking in the dash.. But Is there any trick or way I can get the beepbeepbeepbeep line to stop leaking?
The faring doesn't seem like it'd stop the hose from leaking.
Old 01-22-2007, 03:29 PM
Drrm80 Drrm80 is offline
Did you ever solve this problem? My boost flutters at 15psi and it sounds like its leaking from the guage but i have it in there right i believe? Guage is brand new Autometer
Old 01-23-2007, 04:05 PM
fordnut85 fordnut85 is offline
7.3 tech, supporter
where are you getting your reading from?? did you tap into the MAP sensor line or elsewhere?
Old 01-23-2007, 04:11 PM
map sensor line about 3" away from the sensor
Old 01-23-2007, 04:19 PM
7.3 tech, supporter
i would check the little plastic y they gave you with the guage. mine was really brittle and i cracked it when i installed the guage so i went to the plumbing store and bought a brass one.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
