Fuel bowl issues - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 25 Old 05-16-2017, 12:14 PM Thread Starter
Quoted: 14 Post(s)
Fuel bowl issues
Hello everyone. I have a 1995 7.3 powerstroke and I took my fuel bowl out and apart to rebuild it. Cause research said it could cause a no start if there are faulty parts in it. And I'm looking at it and the element inside is definitely different then all the ones I've seen. Like where's the connection wire. Etc. Please help me out. Thanks!
Sent from my Z963VL using Tapatalk
hoerle7315 is offline
post #2 of 25 Old 05-16-2017, 12:19 PM
Heavy_GD's Avatar
Quoted: 1656 Post(s)
Feedback Score: 3 reviews
@Corey@CNCFAB ...
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #3 of 25 Old 05-16-2017, 12:32 PM
elephantrider's Avatar
Quoted: 152 Post(s)
dang, that's a dirty bowl !
02 joke
elephantrider is offline
post #4 of 25 Old 05-16-2017, 12:34 PM Thread Starter
Quoted: 14 Post(s)
Truck has 265xxx on it I bought it off a guy that let it set for a year. He said the injectors were bad but that's to odd in my opinion for all 8 to be bad so I did my research and the heater element is a cause of no start and mine doesn't even have a wire or a soldered connection on it. So I'm Gona clean it and the gas sending unit in the side of the bowl up and replace parts on it
post #5 of 25 Old 05-16-2017, 01:50 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
You don't need the fuel heater. That is the plate part of the heater and the "element" (bare wire portion) is long gone. Cheers!
Patrick Feeley is offline
post #6 of 25 Old 05-16-2017, 01:52 PM Thread Starter
Quoted: 14 Post(s)
Why would they have replacement parts if you didn't need it?
post #7 of 25 Old 05-16-2017, 02:21 PM
Quoted: 862 Post(s)
It's pointless to have the heater element. Fuel is much different now from 1995.
Sent from my SM-G900V using Tapatalk
Corey@CNCFAB is offline
post #8 of 25 Old 05-16-2017, 02:23 PM Thread Starter
Quoted: 14 Post(s)
So that's not my no start issue. Oh well least I'll have a clean fuel bowl
Corey@CNCFAB likes this.
post #9 of 25 Old 05-16-2017, 08:41 PM
Quoted: 91 Post(s)
I had sand in my fuel bowl when I first got my truck.
Any more specifics on the not start issue?
White95f250 is offline
post #10 of 25 Old 05-17-2017, 12:43 AM Thread Starter
Quoted: 14 Post(s)
The guy thought the injectors were bad so he let is set for a year. I changed the cps. New batteries. And now messing with the fuel bowl
