1999 V10 ZF5 to 1997 Powerstroke - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-11-2017, 10:44 AM Thread Starter
Hey guys,
I have looked and looked but apparently my searching needs help as I am sure is a thread for this already.
But I have found a ZF5 Transmission out of a 1999 Superduty 4x4 with a V10 gasser. I am wondering if that tranny will fit in my 1997 Powerstroke Extended Cab F250 4x4 with a ZF5. This is not an Auto to Manual swap. Just a replacement.
aceballplayer15 is offline
post #2 of 4 Old 02-11-2017, 08:06 PM
Quoted: 86 Post(s)
Not too sure. I know the 460 ZF5 will but you might need to post up pics
White95f250 is offline
post #3 of 4 Old 02-11-2017, 10:41 PM
SuperchargedPSD's Avatar
Quoted: 99 Post(s)
The bell housing pattern may be different? Also the gear ratios may likely be different as they are different between the Zf5 behind a 460 and the 7.3 ZF5
97 4x4 Eaton supercharged 7.3, S369sxe R&D IDI performance T4 mount, my B350/200s, my tuning, honey badger SR hpop, Valair Ceramic single, BMW M3 bucket seats, SKY 5" RSK/Skyjacker TTB , SKY RFK & shackles, Toyo M/T
Waiting on installation: more fuel system parts
1948 GMC 4-53T Detroit, 1945 Chevy rat rod dually 4-51 Detroit, project mean green 8V53 Detroit, 1951 Mack A51T
SuperchargedPSD is offline
post #4 of 4 Old 02-12-2017, 07:20 AM
Quoted: 53 Post(s)
A ZF5 from a 460 will "fit"; it will NOT bolt up without modifying the bolt pattern (which people have done; it's that close). PROBABLY the same for a tranny that came from behind a V10. Easy way to find out - if you read of tranny / engine swaps (without mods) between a V10 and a 460, that means the V10 bolt pattern is the same as a 460, and therefore DIFFERENT from the diesel.
Gear ratio difference has no impact on whether it can be done. A lot of people swap in a gasser ZF5 (with the above-mentioned mod) precisely because they prefer the ratios of the gasser version of the trans.
Kind of a surprise to hear they were still putting ZF5s in by the time the V10 came along; by then, they were putting ZF6s behind the diesels.
madpogue is offline
