Transmission Trouble - Ford Powerstroke Diesel Forum
Old 03-17-2007, 05:56 PM
I was driving about 65 in OD and it popped into Drive and the OD light started flashing. It shifts hard from 1-2 but is fine from 2-3? New Transmission or maybe a sensor or solenoid??
Sorry wrong forum. This can be moved to the trannie problem forum
Old 03-17-2007, 06:11 PM
Powerstroke Techie
Send a message via Yahoo to gbear
I'd say, #1 check the fluid level. Then get the codes read for the transmission. The flashing OD light means one should be set.
Jim
Old 03-17-2007, 07:37 PM
7.3 tech, supporter
Jim
Ditto, sounds like a pump failure
