possible coolant leak from passenger side head - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-01-2017, 05:16 PM Thread Starter
Well I just got done replacing my failed gpr and I noticed what looked like water on the bottom of my oil pan. It looked like it had some color to it, so it may be more than just water. Then I found a pink drop on the trans line just below the starter. The side of the oil pan on the starter side was damp. I do have an oil leak on that side so that is making it hard to see whats what.
No oil or coolant contamination. No fuel in degas bottle. I did just swap out the water pump and I had no leaks after that.
Funny thing is I took it for a ride for about 20 minutes testing out my new torque setup and when I got home it was all dry??? Anyway this may be a wild goose chase, just wondering what could leak coolant above the starter?
Thank you,
Kristian
Current diesels: 97 Quigley E350 7.3, 2005 Passat TDI
KPEC is offline
post #2 of 3 Old 02-02-2017, 04:20 PM Thread Starter
Well it must have been a freak thing, I checked again after a couple of drives and all dry....
KPEC is offline
post #3 of 3 Old 02-02-2017, 04:23 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
There is a block drain above the starter. Cheers!
Patrick Feeley is offline
