Glow plug relay question - Page 2 - Ford Powerstroke Diesel Forum
 4Likes
post #11 of 13 Old 01-29-2017, 11:00 AM
IU 89's Avatar
Western GPR install
Is the installation process (wires to terminals) straight forward? There are instructions on website but specify hydraulic units (Cable/Solenoid Operated), not a specific GPR application. Wire colors appear to be the same but just want to check. Thank you for reading my stupid question.
1997 F350 4x4 CCLB 3"DP 4" straight pipe, EGT, Trans Temp, Boost. Transcooler, EBPV Delete, Intercooler, 6637 Intake, 6 Pos Chip (canned tunes - will need to fix that), 4.10 gears, 315 Toyo Open Country
IU 89 is offline
post #12 of 13 Old 01-29-2017, 11:27 AM
Quoted: 818 Post(s)
It doesn't matter which way you put the wires on. Small wires on small terminals, big wire on big terminals.
Sometimes you can still read correct voltage across the terminals, but that doesn't mean you have full current going across the contactor.
Sent from my SM-G900V using Tapatalk
Corey@CNCFAB is offline
The Following 2 Users Say Thank You to Corey@CNCFAB For This Useful Post:
IU 89 (01-29-2017)
post #13 of 13 Old 01-29-2017, 12:17 PM
IU 89's Avatar
Thank you..They made it Chris proof.
partyman97_3 likes this.
IU 89 is offline
