Turbo spooling. Problem or normal? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-28-2017, 12:43 PM Thread Starter
Hey guys this might be a silly question. My turbo starts to spool around 2000RPM while moving but If I'm in neutral(5speed) sitting still and I rev over 2000 my turbo won't spool. Is that normal? Is it only supposed to spool when moving?
Krome is offline
post #2 of 6 Old 01-28-2017, 04:32 PM
That Other Guy's Avatar
Quoted: 4 Post(s)
Your not loading it while in neutral, you can rev it till it blows and probly only register 3 psi or so.
Its normal, your loading it while rhe vehicle is moving and that is why you can build psi.
EDIT: around 2k rpm is when you say it starts to spool, throttle matted in gear on a hard acceleration obviously whats your max psi youve seen if you have a boost gauge?
97 toredor red metallic f350 XLT CCLB ZF5 7.3 4wd
HPO X-over, riff raff up pipes, 1.00 housing, WWII, 3" dp, 4" exhaust, Tymar intake, riff raff boots, 6.0 fan, tow pig in progress
15 white wrangler jku auto 4" MOPAR lift, fox remote res shocks, fox dampner, black rufino nitros, sun shades, hand grips, floor mats, blah ,blah.
00 Dutchman classic 30' 5er
GN attachment in pin box, new roof compliments of wood rot due to leaks, updating interior currently a work in progress.
That Other Guy is offline
post #3 of 6 Old 01-28-2017, 08:01 PM Thread Starter
My max psi I've seen about 30. But that was when I first got the truck I drive pretty conservatively so I don't really like to push it too hard.
Krome is offline
post #4 of 6 Old 01-31-2017, 09:38 AM
Justin@DP-Tuner's Avatar
Quoted: 56 Post(s)
As stated, you will not build boost without load. Free revving in park or neutral will yield maybe only a couple pounds of boost.
So yes, I would say what you are seeing is completely normal.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #5 of 6 Old 01-31-2017, 09:43 AM
elephantrider's Avatar
Quoted: 146 Post(s)
another vote for normality. you're not loading the snail, so
it won't build boost.
02 joke
elephantrider is offline
post #6 of 6 Old 01-31-2017, 10:32 AM
Quoted: 4 Post(s)
If you can register 30psi while loading it you have no issues with your turbo, do you have a tuner on it?
