clutch slave cylinder - Ford Powerstroke Diesel Forum
Old 03-16-2007, 02:09 PM
hey my clutch slave cylinder cracked yesterday i got the new one and have it all connected but i cant bleed it. If any one has instructions on how to do that i would appreciate it. It seem I always have isuue with getting things blead so Im sure its me but i need some help thanks!
Old 03-16-2007, 02:14 PM
BIG TRUCK, SMALL DRIVER
Does it have a bleeder on it? These things are PITA's!
Old 03-16-2007, 02:17 PM
i took the cap off and filled it full then pumped the clutch 20 or 30 times then filled it back up and pumped it somemore and it feels great. mine didnt have a bleader on it either.
Old 03-16-2007, 02:20 PM
yeah no bleader... Im pumping and the fluid level is not going down. I sould pump with the cap off correct
Old 03-16-2007, 02:26 PM
This may sound wierd, but I have had luck pumping the pedal really fast and taking short strokes, then long slow strokes. I told you it would sound wierd!
I have done these several times, and they all seem to like something different. Try several different things, like above. Try with the cap on and off. I have let them sit over night and the air worked its way up. Keep an eye on the fluid.
Old 03-16-2007, 02:41 PM
try pumping the clutch several times and have someone losen the fitting on the slave cylinder while you are holding the clutch down tighten the fitting before releasing the clutch. try that several times. that should get most of the air out.
Old 03-17-2007, 02:22 PM
7.3 tech, supporter
Don't try and bleed it with it in place, remove it and hold it with the hose end up so any air will travel up the hose while you have someone pump the pedal for ya.
