94 powerstroke - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-07-2009, 11:15 PM Thread Starter
94 powerstroke
Hi guys, Im looking at a 94 powerstroke and i was just wondering, being the first year of the powerstroke were they ok? Iv always heard steer clear of the first years but wanted diesels are pretty new to me and wanted some advice. Thanks
Brad_9876 is offline
post #2 of 5 Old 11-09-2009, 06:30 AM
cndrm's Avatar
Ok. Ford offered 2 different versions of the 7.3L diesel in the '94 model year.
First, they offered the 7.3L IDI (indirect injection). I believe this model came with a turbo from the factory. The IDI is a simpler version of the 7.3L. It doesn't have a lot of the electronics, HPOP, etc. that the DI (direct injection) version came with. There's nothing wrong with this motor at all.
Second, they offered the 7.3L DI "Powerstroke" diesel. This model is factory turbocharged, and really isn't any different from a '97 or '98 model truck with the 7.3L PSD. And, as a matter of fact, I have an early model PSD. My truck is a " '95", but it was made 12/94. I have had very good luck with my truck, and so did it's past 3 owners. (2 of which wanted to buy it back from the 3rd) I personally don't think there's any difference at all, and I wouldn't hesitate to buy an early PSD over a newer one.
Hope this helps.
mike
Don't burn your bridges, you might have to cross them again in life.
Don't sugar coat things. It covers up the taste of real life.
Providentia Remedium Belli
Early 1995 F-350 Crew Cab Long Bed
33" Hankook RT03 Muders
DIY Intake w/ Napa 6637 filter
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Upgraded gear reduction starter
Bypass Oil System
Bypass/ Coolant filter system
Gauges
Built Tranny
cndrm is offline
post #3 of 5 Old 11-09-2009, 11:05 AM
X2! I have a 94.5 with the PSD and i love it. I use it to tow my landscaping equipment on a weekly basis. I like the older trucks better than the newer ones, seems to me they are easier for novice mechanic person to work on. No problems with mine except standard things: lift pump, vaccuum pump, and a couple of oil leaks. All in all great truck!
1994 F250
PSD All Stock
Reg.Cab Long Bed
OriginalStroker is offline
post #4 of 5 Old 11-09-2009, 11:29 AM
dbkerley's Avatar
I'm pretty much in the same boat as everyone else. Early on I let my ignorance beat me to death and spent too much money on things I should have fixed myself. Now, I just drive it.
Brad
dbkerley is offline
post #5 of 5 Old 11-09-2009, 12:22 PM
ridiculously_necessary's Avatar
i have a 5 built in 94 as well. love it! as mentioned above the fuel pump, vacuum pump leave somethign to be desired but they are cheap and easy to replace.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
