So I finally got back into another OBS truck. I deleted my facebook so I'm back on the forum full time! Just want to throw out a couple pictures and my plans. Love the new truck!
1996 F350 2wd Dually 7.3 Centurion Package
Here are my plans
Needs front end work. Already did ball joints and steering box, need to do radius arm bushings and tie rod ends.
Upgrade to 5" exhaust with a muffler (needed for safety inspection)
Get custom tunes on the TS6 chip. I'm worried about the quality of the canned tunes it came with from previous owner.
Already got the automatic transmission rebuilt with upgraded converter and other components including a good fluid cooler.
Riff Raff Intake kit (coming very soon)
New Gauges already sitting on the work bench. Just need them installed.
Need to do a coolant flush to get the nasty green stuff out. Add CAT ELC EC1 coolant and do a full flush. Have a 203 degree thermostat to go in then as well. Need to get a coolant filter to add then too.
Already got new tint
Already got new tires, Toyo open country AT
Need to replace the O ring on the dip stick adapter to stop an oil leak
Already replaced the door pin bushings to make the doors shut easier and quieter
Already did brakes all around.
And I want to add some random led lighting. Light bar facing the rear and some smaller ditch lights. That would help when setting up the camper in the dark.
A lot of random thoughts there, just wanted to throw it out and see if anyone has any cool opinions. Thanks guys!
Here are my plans
