Srange Transmission Behavior - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 15 Old 02-01-2017, 08:21 AM
Quoted: 91 Post(s)
Any changes you do you need to let the transmission do a relearn. Either unhook batteries or clear it with a scanner
White95f250 is offline
post #12 of 15 Old 02-01-2017, 10:42 AM
Quoted: 54 Post(s)
The transmission doesn't "learn", nor does the PCM.
Does the center stop light in the cab roof work? That's also a player in the whole byzantine brake light / LED / pedal switch / TC lock-unlock melee.
I had an odd thing happen recently along these lines. It's a manual, but a similar situation. I removed the center stop light bulb a while back, because the truck has a topper, and that bulb gets hot. Only effect was, cruise control would interrupt when I hit the turn signal. The goofy way the truck is wired, that sent a dummy "brake pedal on" signal to the PCM, thus canceling the cruise. This is the equivalent to automatic trucks unlocking the torque converter when the PCM receives a brake pedal signal.
Couple weeks ago, cruise became inop completely. I checked every circuit, brake lights weren't stuck on, steering wheel switches all checked out, fuses checked out, yada yada. Finally I plugged her into AE, and sure enough, the "brake pedal pressed" (or whatever it's labeled in AE) was set to "1", meaning the PCM THOUGHT I was pressing the brake pedal. For S&G, I turned off the key, re-installed the bulb in the CHMSL socket, lit it back up, and the brake pedal (BOO) signal went back to "0".
For MONTHS, this was not a problem. I didn't actually monitor it, but I bet that previously, the signal according to the PCM would remain 0, and go to 1 only when I hit the brake pedal, or hit the turn signal. It was totally out of the blue that it went to 1 at all times that the key is on, and went to 0 again when I re-installed the bulb.
I don't have an LED in that denomination of bulb, so I don't know what impact that will have on how the PCM reads the brake pedal.
It stands to reason that it won't throw a code. It has no way of knowing the difference between a false BOO signal like described above and a real one when you press the pedal. Similar to when your CPS fails, often it doesn't throw a code because it doesn't know the difference between the failed sensor and the engine actually not turning.
In any event, while troubleshooting this, if you have a way of reading live PCM data, that would help. Set it to read brake pedal state, and monitor it as you fiddle with different bulbs, resistors, etc. The goal is to see it only switch from 0 to 1 and back to 0 based on the pedal.
madpogue is offline
post #13 of 15 Old 02-01-2017, 10:50 AM Thread Starter
Quoted: 9 Post(s)
I do not have a way to read live PCM data. You mention AG. What is that or are there any low cost tools out there that I can get to read this data. I don't think it is a brake on issue because I have issues with it locking early and staying locked until I completely stop. But it could be that it is not getting the break on signal when it should to unlock. Either way it sounds like reading Live PCM data is going to be a help.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #14 of 15 Old 02-01-2017, 02:37 PM
Quoted: 54 Post(s)
The cheap option, IF you have an Android phone/device, is to get a Bluetooth wireless dongle for the data port, and the Torque Pro app. Over on "the Nation", there's a LOOOOONG thread on the topic. Takes some tweaking to get working, as I recall.
madpogue is offline
post #15 of 15 Old 04-03-2017, 09:27 AM Thread Starter
Quoted: 9 Post(s)
I FINALLY FIGURED IT OUT!!! I finally found an app that would actually talk to my truck. For whatever reason Torque Pro would not talk to my PCM. I found in another thread on this site that someone recommended the Car Gauge Pro and Car Diagnostic Pro apps. They were $8 total and they had no trouble talking to my truck and my brother in law (a Torque Pro) uses said that they had more pids that work right out of the box then he had in Torque and he had a hard time getting those to work. Now back to the story. I found 2 codes in my computer. 1 for the Exhaust Back Pressure sensor and 1 for a Electronic pressure control. So I changed the Back Pressure pipe and the sensor then I changes my solenoid pack inside the trans and so far it has not shifted any better then it does right now. Hopefully it will last for a little while at least.
