10k resistor mod questions - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-12-2009, 12:58 PM Thread Starter
strokin95style's Avatar
Been tryin to search through the threads for more info on the 10k resistor mod, and i decided to go to radio shack and get a pack. I asked for a pack of 10k resistors and he asked if i wanted a 1/2 watt or 1/4 watt pack. I was stumped. I went with the 1/2 watt, will or will these not work in my 95? Would like to know before they close this afternoon. Any help would be greatly appreciated. Thanks guys.
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
post #2 of 7 Old 10-12-2009, 01:04 PM
pickupman99's Avatar
just search for it on this site ive done it before on a truck at work with a 7.3 but not sure of the wattage. theres been a bunch of threads about the resistors so it cant be hard to find it. also ive heard that using a resistor with a programmer like edge it says you have in your sig. can be bad for them not sure exactly what happens, but have heard its not good
early 99 F-350 afe stage2, straight 5 TBE, ts 6 pos., suncoast tranny&tc, snow performance meth., 300cc 200 % over hybrids, turbonetics ball-bearing, adrenaline hpop, dick cepek fc IIs on micky thompson classic IIs, 2" shakle in front and add-a-leaf out back, 15% tint, ccv dumped under cab
"You can set my truck on fire and roll it down a hill and still wouldn't trade it for a coupe de ville."
pickupman99 is offline
post #3 of 7 Old 10-12-2009, 01:07 PM
Either will work: Ford Powerstroke 10k Mod
Randy DuCharme (Radio AD5GB)
'06 F-250 FX4 A/T Super Cab short box.
SCT SF3 tuner /w Gearhead Performance custom tunes. ARP head studs, EGR delete, oil cooler/drainback tube/STC coupler/blue spring/standpipe & dummy plug upgrades, ScanGauge II, Sinister Diesel coolant filter, Fumoto drain valves, Stage II direct clutch and ECP solenoids.
AD5GB is offline
post #4 of 7 Old 10-12-2009, 02:16 PM
z250kid's Avatar
some websites sell them with it in it already
i know beansdieselperformace does
also 100$
1996 F350 4x4 Powerstroke Diesel
Afe Stage 2
3 Inch Downpipe,Cat-Delete,90 degree elbow(ss)
Diy Exhust Brake
Hpx Crossover
z250kid is offline
post #5 of 7 Old 10-12-2009, 02:40 PM Thread Starter
my radio shack sucks...they have the 10k and a 4.7k. only way to get a 5.6k is to buy a pack of 500 for like $13. tried the 4.7k, power cuts off after about 2,300 rpm, got the 10k, decent throttle response, but im lookin for a resistor somewhere in between. thanks for the info guys.
Nater
1995 f-250 rclb
3" Downpipe
Dana 60 s.a.s
post #6 of 7 Old 10-12-2009, 04:19 PM
Two 10K resistors in parallel == 5K. Add a 560 or 680 ohm (not K-ohm) in series to the parallel pair you just built and you will be close enough to 5.6k that whatever difference there is will be negligable.
AD5GB is offline
post #7 of 7 Old 10-22-2009, 12:40 AM
redneckabbott's Avatar
Has anyone seen high egts with just resistors? I dont have gauges but wanting to do this. Wouldn't be running the ole girl WOT either.
Decided I'll just keep things the way they are.
redneckabbott is offline
