OBS Rotors
Are the OBS rotors (truck is a 97) floating or is it the whole big hub piece with the studs and bearing races inside it?
all one piece man! now the rear drums go over the hub tho.
Alrighty, thought so, thats what i needed. Anyone else care to differ?
now on the other hand, the sd rotors go over the hubs.
2wd rotors are one peice with hub and studs. 4wd Rotors are NOT part of the hub.
When you get your new rotors, you pound the studs out of the hub and rotor. Then you take the hub off, and put your new rotor on the backside, and pound the studs back in. The studs hold the rotor and hub together. Hope that helps. |
Yay, conflicting info. Anyone else? I need to know by tomorrow.
jake whos truck, and you didnt state 4x2 or 4x4
I agree with wearewierd. Done mine plenty of times
A guy named Blake, he just signed up here, but isn't on much. Its 4X4. I have the whole hub/rotor assembly off. To me it looks to be one piece. Unless its just rusted together that much. We beat the f**k out of it with a 10 lb hammer and it still didn't come apart, all that happened was we broke chunks off the rotor.
you can kinda see the lip between the rotor and hub here...
![]() You guys had me doubting myself, lol I dont usually give out bad info. |
