I need of a Ball Jointed D60 - Ford Powerstroke Diesel Forum
Old 10-11-2009, 04:56 PM
I have been searching for a while and can't seem to lay down a Dana 60 with ball joints for under 1,000 can anyone give me some ideas on where or how to pick up one The junk yards around here want almost 2,000 for one. I twould be much appreciated thanks
Randy
Old 10-11-2009, 08:15 PM
Got an offer on Cl for 1100 new brakes
Old 10-12-2009, 09:00 AM
Bought mine two weeks ago for $700 + my stock axle setup. I also got the F-350 springs that I won't be using since I went straight to lift springs. Your best bet is to find one from a private seller
Old 10-13-2009, 03:59 PM
I have a ball joint Dana 60 Front from a 1997 F350, complete from hub to hub with all accessories(Ubolts, and plates, Brakelines, tie rods, sway bar and driveline) I pulled mine out cause I put in a Dana70Front dually with a Dana 80 Rear Dually, so there is nothing wrong with mine. 3.54 gears, Open diff, completely stock from a California Powerstroke.
Located in Central CA (fresno) Asking $1200 for it complete and I can included a Sterling matching rear axle for another $100
Feel free to contact me at: BBrianR@yahoo.com
Thanks
Brian
Old 10-13-2009, 04:35 PM
Thanks but I just picked up a D60 today for 750 but if you have the track bar and braket I might take those off your hands
Old 10-14-2009, 05:49 AM
What did Dana 70 front's come in? Never heard of that combo!
Old 10-14-2009, 08:29 AM
I found the Dana 70 front in a wrecking yard, under a 1995 4x4 FSuperduty tow truck. 10 Lug, Large Disk brakes, all Dana 70 Front parts(ie 35 spline outer shafts, larger tubes than the Dana 60, bigger knuckles). It is cast 70F and was definitely a front axle, but I believe that the center section came from a older dodge, that someone re-tubed it, and make it a drivers drop and set it up for OBS ford.
The rear is a Dana 80 from a 1996 FSuperDuty with 10 lug and disk brakes. I pulled out the 5.13 gears in both and dropped in 3.73 with lockers.
