!!!!need help my truck is losing power!!!! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-11-2009, 01:51 PM Thread Starter
strokensambo7.3's Avatar
I have a 95 f250 7.3 it idles fine and starts fine. Runs good when cold but when it warms up dont pull so well uphill. If some one can help me PLEASE
strokensambo7.3 is offline
post #2 of 11 Old 10-11-2009, 05:26 PM
sgt dave's Avatar
Quoted: 3 Post(s)
check the oil level. if not enough oil, hpop wont fire injectors right.
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #3 of 11 Old 10-11-2009, 05:55 PM Thread Starter
i just put fresh oil and filter on it 2 weeks ago and it is still hesitating mostly uphill some time on straight. I ran it low a time or two! I hope i didnt damage anything.
thanks for your input
post #4 of 11 Old 10-12-2009, 03:38 AM
cndrm's Avatar
If you just changed the oil, and the level is good, it could be your thermostat. My truck runs much stronger when it's on the cool side than when it does when it's really warm. I'd bet your thermostat is getting a little long in the tooth, and is in need of a change out.
mike
Don't burn your bridges, you might have to cross them again in life.
Don't sugar coat things. It covers up the taste of real life.
Providentia Remedium Belli
Early 1995 F-350 Crew Cab Long Bed
33" Hankook RT03 Muders
DIY Intake w/ Napa 6637 filter
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Upgraded gear reduction starter
Bypass Oil System
Bypass/ Coolant filter system
Gauges
Built Tranny
cndrm is offline
post #5 of 11 Old 10-12-2009, 02:19 PM Thread Starter
i scaned it today and the code p0603 (kam) came up. I dont know if it the same problem but today not a good day for it
post #6 of 11 Old 10-13-2009, 03:55 AM
cndrm's Avatar
Okay, I looked up your code, and this is the description I got:
P0603/ PCED/ KAM memory loss/ No historical faults output durring a KOEO test/ Open PCM pin, Disconnected B+, Faulty PCM.
Seems that your issue is with the PCM. (Powertrain Control Moduel)
Hope this helps.
mike
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Bypass Oil System
Gauges
Built Tranny
cndrm is offline
post #7 of 11 Old 10-13-2009, 07:44 PM
billydakid1567's Avatar
Send a message via AIM to billydakid1567
did you happen to change the fuel filters and clean the injectors i was having the same issue in my old 97 psd it turned out to be the water in the tank fuel fiter was dirty but i never had a code showing on mine...
1997 7.3 stroker
" If it ain't strokin' it ain't smokin' "
Ts performance 6 bank
Cold air intake
5 inch stainless silver line stacks
Pilar gauges
Touch screen flip screen dvd player
6 inch skyjacker lift
pro comp xtreme at 37x13.50r20 tires
20 inch moto metel wheels
billydakid1567 is offline
post #8 of 11 Old 10-18-2009, 11:05 AM Thread Starter
THANKS to u all u guys help a whole lot. past few days i put a thermostat, fuel filter, disconnect B+ and air filter. my truck is runing better and no codes. im really happy the truck has 400,000 miles and runs this good.
( thank again )
post #9 of 11 Old 10-19-2009, 08:04 AM
ridiculously_necessary's Avatar
good to know we could help. put your truck spec and espicially the mileage in your signature!
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #10 of 11 Old 10-19-2009, 10:02 PM
wannapowerstroke's Avatar
Excuse my lack of knowledge but what is "disconnect B+"? as stated by the author? Thanks - trying to learn
wannapowerstroke is offline
