Where is the weep hole??? - Ford Powerstroke Diesel Forum
Old 10-11-2009, 11:13 AM
Hey folks,
I've got a pretty good fuel leak that is dripping down from the rear of the engine. I believe its come from somewhere in valley, but I can't see it. As a note too, I have a California truck that has the Bosch disk.
I was hoping to see the weep hole on the fuel pump to see if it's coming from the pump or not. But I can't find it. Can someone show me a pic of the pump and the weep hole?
Also, I originally thought I saw fuel dripping from the edge of the Bosch disk. Do they have a seam or anything that leaks?
I hate to sound dumb, but the reading I've done on the forum also talks a lot about a banjo bolt. I don't know what that is or looks like either, so if someone could show me a pic of one I'd appreciate it.
Thank you!
Old 10-11-2009, 12:10 PM
Other vehicle is an F250
The weep would be hard to see without taking the crap off the engine. Soak the valley in degreaser, hit it with a powerful stream of water. Crank her up to dry and watch for the leak.
Old 10-11-2009, 04:29 PM
if the three hoses coming off of the fuel pump to filter housing are original, they are probably leaking. check there also.
Old 10-11-2009, 08:29 PM
Interior Guru
Feedback Score: 3 reviews
Here are some pictures for you. I dont have a CA truck, but this should help you out.
You can see the banjo bolt there. Its a MF'r to get in and out if you have big hands, but its possible!
The blue hose is one of the hoses Sgt Dave is talking about, they crack and will leak. Replace the pump and hoses if you have a leak in the valley. 9 times out of ten, its one of those two things.
Id change them anyway, including the lift pump, and then inspect the fuel bowl for leaks or cracks etc. while its out.
Old 10-12-2009, 02:27 AM
I wouldn't waste your time trying to see the weep hole. Just start looking around for a pump (somewhere between 100-200 bucks), and get yourself 3/8", 5/16", and 1/4" fuel line. You'll also need a 1 1/4" box end wrench. (Your local Napa should have everything, though Napa's price on the pumps is up there)
mike
Old 10-12-2009, 04:54 PM
here is a cali fuel pump: The number 4 is the Banjo bolt.
Where is the weep hole???-cali-fuel-pump.jpg   Where is the weep hole???-california_fp_only.jpg
Old 10-12-2009, 05:02 PM
Interior Guru
That is the most retarded place for that....
Old 10-13-2009, 02:39 AM
Yep, that's a cali truck alright. But, one thing to keep in mind. I have a Cali truck, and I don't have that goofy black disc thingie. I think the black disc thingie is on '96-'98 trucks. (mine's a '95)
mike
Old 10-13-2009, 06:29 AM
whats it for anyway?
Old 10-13-2009, 08:54 AM
IIRC its function is to dampner (spell?) the pulses of the fuel pump.
