cat gut question - Ford Powerstroke Diesel Forum
Old 10-09-2009, 02:34 PM
cat gut question
I pulled the truck into the barn this afternoon to pull the cat off and gut it. I was able to get the U clamp loose however the clam shell bolts turned out to be a no go. I sprayed the bolts down with some PB blaster to soak for a while. My question is, can I cut the two bolts with a sawzall and replace with two new bolts or is the two bolts part of the clamshell?
I'm gonna gut the cat for now and then later on get a dp and a cat delete section or a new exhaust from turbo back of some sort.
Thanks
Randy
Old 10-09-2009, 02:49 PM
yea unfotunetly they are, i had the same problem, gonna have to get downpipe. What i did was i bought a downpipe that has the flange to bolt up to the cat and a cat delete pipe, so that way if i need the cat in the future for emissions i can pop it on with the new downpipe.
Old 10-09-2009, 03:02 PM
Tennessee Powerstrokes
My guy cut the cat out and after inspection welded it back in. You would be hard peassed to tell anything has been done.
