need help with gauge lights - Ford Powerstroke Diesel Forum
Old 10-09-2009, 01:39 PM
Send a message via AIM to billydakid1567
Exclamation need help with gauge lights
hey need help with hooking up my gauge lights i want them to be to my dimmer switch just cant figure out the wires i need tap in too for my pillar gauges
thank yous
Old 10-09-2009, 01:57 PM
If it aint a CAT itsa DOG
On my 01 i used the light blue wire with a red trace that was connected to my dimmer switch. I would take off your light panel and test to see which wire will get power and them dim when its turned up/down. Tap into that wire. I don't know if your colors will be the same on an OBS. Here is the link i used from diesel manor.
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old 10-09-2009, 02:05 PM
thanks any way man but i wont work due to me having the pull out light switch and the dimmer in that as well not two seperate things
Old 10-09-2009, 02:53 PM
i used the dimmer wire on the radio. If you have an aftermatker radio installed it doesnt use need that wire since mst have a constant light.. ill check what color it is for you tommorow, or pull out your radio and see if you can determin it by holding a multi meter to each wire
Old 10-11-2009, 12:57 PM
Get a fuse adapter,tie it in to the #10 fuse it well work off of the dimmer them.
