starter wining and grinding(replace it twice) - Ford Powerstroke Diesel Forum
Old 10-05-2009, 12:08 PM
Send a message via AIM to billydakid1567
Angry starter wining and grinding(replace it twice)
another issue i have is that my starter wines and grinds some times and if i go form reverse to park then shut it off and later go to start it it does it every time i replace the starter twice in the last 8 months.. can you shim a ford starter ??? or do you think it would be the flex plate... or what..
Old 10-05-2009, 12:12 PM
does your fly wheel have all its teeth? my first truck had this problem, PO went through 3 or 4 starters, when i got it we found the fly was missing teeth and destroying the starters.
Old 10-05-2009, 12:17 PM
um not sure everytime i replaced them the teeth where good looking from just looking in the hole when the starter was off ... would i be able to move the flywheel around to check it >>>
Old 10-05-2009, 12:22 PM
never done it on a diesel, ill let someone else chime in on that one.
Old 10-05-2009, 01:12 PM
mine does the same thing. my dad is a diesel mechanics working at a bus garage and before that a shop. he told me mine is prob the flywheel he said he didn't know of any way to look at the flywheel with out drop in the trany. he was also telling me that some times the starters can be rebuilt instead of putting a whole new one in
Old 10-05-2009, 02:06 PM
yake the inspection cover off the bottom of the tranny ,im prety sure you can see the flywheel from there.
Old 10-06-2009, 05:41 PM
is the pinnion gear on the starter chewed up? if so you have an alignment problem or your ring gear might be missin teeth. you can check it with a big enough screw driver. c
