gets pissed when in 3rd - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-22-2009, 06:42 PM Thread Starter
95pstroker's Avatar
my 95 wants to spit it out of gear when i put in 3rd and get on it. if i hold it in and slowly accerate it stays. tranny also rattles when im at idle. all the other gears are fine. also what kinda of mpgs are you guys getting? i got 180 just on one tank (15 gal) that was with my tune turned up. will i get better running it on stock for long hauls?
95 Stroker~4.10 gears~5spd~4x4~AFE intake~3in downpipe to 5in single stack~TS 6 level chip~hpop
95pstroker is offline
post #2 of 5 Old 09-23-2009, 07:36 AM
SuperDuty73's Avatar
Im guessing a new shift solenoid is in need at least. thats what im looking for. My truck doesnt stay in a high gear unless im on it.
Mark
1996
Powerstroke
133,000 and counting...
The Works:
~ Ported Turbo & 1.0 Hot Housing
~ Turbo blanket
~ Ceramic Manifolds
~ Wrapped Up-pipes
~ Banks Technicooler
~ 3" Superduty Plenums
~ Custom 6" AEM Intake
~ Tymar 3-4" Ceramic DP
~ MBRP 4" Exhaust
~ BB Mod
~ PHP Tunes
~ Transgo Shift Kit
~ DIY 140v IDM mod
~ Electric Fans
SuperDuty73 is offline
post #3 of 5 Old 09-23-2009, 07:43 AM
My guess would be a failing synchro. I average 17-19 depending on conditions (3.55 gears) but have gotten 21 on a couple of occasions. I do have a slight leak in the valley somewhere but can't tie it up until I get the clutch put in my TDi. Maybe then I'll be able to crowd 21 again.
Randy DuCharme (Radio AD5GB)
'06 F-250 FX4 A/T Super Cab short box.
SCT SF3 tuner /w Gearhead Performance custom tunes. ARP head studs, EGR delete, oil cooler/drainback tube/STC coupler/blue spring/standpipe & dummy plug upgrades, ScanGauge II, Sinister Diesel coolant filter, Fumoto drain valves, Stage II direct clutch and ECP solenoids.
AD5GB is offline
post #4 of 5 Old 09-23-2009, 10:15 AM
my bad didn't know i was a stick.
1996
Powerstroke
The Works:
~ Turbo blanket
~ Ceramic Manifolds
~ Wrapped Up-pipes
~ MBRP 4" Exhaust
~ BB Mod
~ PHP Tunes
~ Transgo Shift Kit
~ DIY 140v IDM mod
~ Electric Fans
post #5 of 5 Old 09-24-2009, 06:27 AM
Chunkspowerstroke's Avatar
I also get 18-21 but I would turn it down when going on long hauls
Chunkspowerstroke is offline
