New guy build thread
OK, here is my story; I am new to the forum and somewhat new to diesels. I have a 95 F350 CC 7.3. The truck has 185K on the chassis but only 85K on the “factory replaced” motor and trans. This past spring I towed my jeep (8500 .lbs) out to Moab, UT and in Colorado I could not maintain 20 mph up the passes. Hell the semis were passing me with no problem up the pass. The motor just seems to be tiered and worn out.
The story gets better. My brother is in college studding diesel engineering technology. He is in need of a project for the spring semester. So the new plan is to have him re-build the motor. Since I am pulling to motor and tearing it apart I figure it is a good time to add some power adders. Guys, what should I do to the motor for more power. This is how it currently sits: DP Tuners chip 20-40-80-120 HP Tymar intake Cobbled together 3.5-4” exhaust 3” downpipe Plans: Bigger injectoers Bigger turbo (which one , not sure) 6.0 intercooler 6 speed swap bigger pump Bigger cam Pistons? What else should I do? Thanks, The new guy |
well first off man welcome! also i think we will need some more info, are you looking for a daily driver, what are your HP goals and such, this will make alot of the decisions on the parts you want much easier
it is NOT a DD, as for HP i think 400 whp would be nice to tow 9K lbs for the single trailer. I also have a 30' goose that weights in at about 18k# fully loaded.
well deffintly a intercooler, i think you will be ok with stage 2 injectors, as for turbo a D66 will do you just fine. i wouldnt go threw the 5 speed swap, it gunna cost as much as a nice BTS built auto trans anyways, your gunna need a good custome chip, TW, Swamps, DP do good jobs as far a tunes, it looks like your set with the exhaust, maybe fix the cob job up alittle but otherwise it seems ok lol, your gunna need a bigger HPOP, you can get a 17* one off of a SD and that should be fine, thats pretty much the basic stuff, Matt P and GMDuraturd should chime in shortly and could probubly add alittle to my list
this is great info, keep it coming. however my brother is pretty set on the standart transmission swap.
I too would suggest the BTS built Tranny. Here is my list...
Stage 2 Injectors Replace mechanical fuel pump with electric 17* HPOP or better head studs D66 turbo TW Chip Intercooler ISS Pro Guages DIY/Tymar Intake thats what come to mind at the moment. your engine may be fine but have other problems, but i wont get into that since your looking for a build. keep us informed! |
I don't know about the BTS tranny, thats some serious coin. Also I forgot to mention that on cold starts it has a lot of blue smoke. Also when its turned up the soot has a blue haze to it, not exactly black.
Thats part fo the reasoning behind an overhaul.
well just by your original post, your going to spend atleast 4-5K already, so i'd go with the BTS tranny as well because they have a great reputation on 4R100'S
agkits.com for the complete motor rebuild kit not to bad on pricing
dpppower.com for the injectors and an h2e turbo seen first hand and have heard they are good little pricey tho |
my plan when i get my 7.3 is:
adrenaline hpop diy stage 3 injectors gtp38r turbo diy regulated return fuel system tymar intake built tranny, oh and TW chip from what i hear most guys running this set-up are around 500hp. oh and dont forget head studs ![]() good luck |
