ZF5 fluid options - Ford Powerstroke Diesel Forum
Old 09-11-2009, 05:22 AM
ZF5 fluid options
I know that it calls for Mercon V synthetic fluid but what other options may I have that would quiet up the noise and smooth up my shifts?
Old 09-11-2009, 06:13 PM
I think I'm gonna' try Schaeffer's 204SAT. The noise of the new clutch is almost unbearable, hoping it will quiet it some.
Old 09-12-2009, 08:38 AM
what is that? Elaborate more please
Old 09-12-2009, 07:03 PM
A full synthetic ATF.
Old 10-31-2009, 03:22 PM
Finally got around to changing to the synthetic fluid (used 5 qts as suggested), you wouldn't think it was the same truck. So quiet I can hear the ole' lady complaining from the passenger seat now.
Old 10-31-2009, 03:37 PM
Shade tree mechanic
Old 10-31-2009, 05:49 PM
A good trick for that is to turn your radio to a talk station and turn the volume down so you can barely hear it, if you're really concentrating on listening to the radio you won't hear a word she's saying and it's a lot less obvious than cranking the radio up.
Old 10-31-2009, 10:09 PM
In my '96 thought the syncros where on the way out, would grind on 3-2 shift so drained and filled with Redline MTF 5 litres, truck now has 460K kilometres on it and is fine.....guessing 150K Kilometres on that oil!!
jrc
